I know cutting the firewall is one way of doing this, my question is, has anyone ever tried lopping off the res/pivot area and welding on a dual master piston assembly? It seems very doable. I know welding cast iron isn't exactly ideal, but it seems like a viable option for a conversion. Obviously you'll have to make sure the reservoir is always full because it will be a small capacity. Just a thought. I may try doing this.
61 Master Cylinder conversion?
-Steve
Re: 61 Master Cylinder conversion?
Anything is possible. Brazing would be a better choice imo. A remote reservoir would increase capacity and make it easier to monitor fluid level.
It is going to be new if I remembered your story published elsewhere.
A guy on a VW site has a 60 Corvair and upgraded the master cylinder with one from a VW Jetta after making a bracket for it.
Here's the link: http://www.kustomcoachwerks.com/forums/ ... &start=315
He's using a remote reservoir.
Pics:
Pics:
Dan
1961 500 Lakewood, 80HP, PG
1964 500 Coupe, 140HP, 4spd (Christene)
1965 Mustang Coupe, 200cid 6cyl, 3spd
