For Sale - 1964 Turbo Cylinder Heads
Buy or Sell Corvair parts.
Nickshu
Unread post by Nickshu » Fri Dec 29, 2017 7:23 am
ForSale - 1964 Turbo cylinder heads - Done by Ken Hand - Less than 600 miles on them.
These heads were the original heads on my '64 Spyder. Ken did them for me (all the work is outlined below) and I used them for about 600 miles then removed them and decided to go with closed chamber heads.
The work Ken did is outlined in the invoice in the next post. It included a comprehensive prep of the heads for durability and dependability.
Ceramic coated exhaust outlets are included (installed).
A piece of metal went in the intake and did some minor damage to the #3 chamber. See the photos...this damage will not affect function. The heads are currently at (and will ship from) Ken's shop - He checked them over and verified there is no issue with using them as is.
Spent over $2300 in head work on them with Ken.
Asking $1500 for them plus shipping from Ken's shop in Michigan, or pickup if you are local to him.
PM with questions or interest. Thanks!
http://i1273.photobucket.com/albums/y41 ... tqpw8.jpeg
http://i1273.photobucket.com/albums/y41 ... rgntp.jpeg
http://i1273.photobucket.com/albums/y41 ... 7vaym.jpeg
http://i1273.photobucket.com/albums/y41 ... 4ngrq.jpeg
http://i1273.photobucket.com/albums/y41 ... u9gyj.jpeg
http://i1273.photobucket.com/albums/y41 ... 6dgk0.jpeg
http://i1273.photobucket.com/albums/y41 ... xwnbm.jpeg
Sent from my SM-G930V using Tapatalk
Nick_______________________________
1964 Monza Spyder Convertible #435 - Rotisserie restored
Check out my restoration thread here: http://corvaircenter.com/phorum/read.php?1,681169
Recreational Mechanic/CORSA Member/COG Supporting Member/Navy Veteran
Nickshu
Re: For Sale - 1964 Turbo Cylinder Heads
Unread post by Nickshu » Fri Dec 29, 2017 7:27 am
Invoice for head work completed by Ken Hand in late 2015;
Description                                   Qty/Hours   Price/Rate       Total
Clean and        Heads                 1           50               $50.00
Inspect
Mill Head        .030                  2           65               $130.00
Gasket Area
Mill Cyl. Head   Top Side              2           100              $200.00
Valve guide,     Bronze                6           45               $270.00
Installed
Valve Guide      Intake                6           35               $210.00
Liner, Bronze
Valve Seat       Exhaust               6           9.5              $57.00
Vavle Seat,                            6           4.5              $27.00
Intake
Valve Seat                             12          35               $420.00
Labor
Port head        Pocket Port           2.5         50               $125.00
Deflash                                2           50               $100.00
Cylinder Head
Valve Grind, 3                         2           89               $178.00
Angle
Intake Valve                           6           6.5              $39.00
Exhaust Valve                          6           15.7             $94.20
Valve Springs                          12          4.35             $52.20
Valve Stem Seal  Viton, Low Friction   6           3                $18.00
Exhaust Sleeve,  Cyl. Head to          6           30               $180.00
Ceramic Coated   Manifold
Labor to         Exhaust Sleeves       1           50               $50.00
Install
Drill and Tap                          0.5         50               $25.00
Broken Bolts
Heli-Coil                              1           25               $25.00
Shipping                               1           65               $65.00
Shipping         Second Box            1           27               $27.00
Subtotal: $2,342.40
Tax: $0.00
Total: $2,342.40
Nickshu
Unread post by Nickshu » Sat Dec 30, 2017 7:38 am
FWIW Ken Hand has offered to repair the cylinder #3 dings if desired for a small fee before shipping. He has also offered to remove all the valves and verify clearances for any interested buyer's piece of mind.
See comments here: http://corvaircenter.com/phorum/read.php?1,956670
Nickshu
Unread post by Nickshu » Mon Jan 01, 2018 12:10 pm
Happy New Years bump! Make me an offer...these heads need a good home on your engine if they are what you are looking for! Not doing any good sitting in Ken's shop. :-)
Nickshu
Unread post by Nickshu » Fri Jan 05, 2018 5:12 pm
Weekend bump...somebody needs these. Make me an offer! Ken will repair #3 if desired for a small fee and verify clearances, but things are pretty much new so should be good to go!
Why buy a set that needs $$$ to be rebuilt when you could have a set that's done by one of the great and most respected Corvair machinists!!
Return to “Parts For Sale”
