Vote for Corvair of the Month APRIL 2015
Voting Now Open
Re: ENTER- Corvair of the Month APRIL 2015
Rondo here, My entry is a 1966 Corsa factory A/C convertable, 140 HP 4 Sp. I purchased it in Dec. of 2010 and did a bumper to bumper resto excluding an engine rebuild. I just completed this project a few weeks ago. This is my first corvair and I really enjoyed this project. The exterior paint is Aztec Bronze. Interior paint is a med.Fawn met.with a white interior and a Fawn/Gray carpet. This car was bought new here in Az. I'm the 3rd owner. Originally white with a marroon interior, the second owner had it painted a maroon as seen in the 1st pic. The whole restoration can be seen in the 66 Restoration posts under Member's Rides Projects and Builds.
1958 Chevy Impala
1966 Corsa Conv.
1966 Corsa Conv.
Here is my 1960 Caveman. Took me about 5yrs to get it done. I have owned it for 8yrs now and did most of the work myself. Thanks for voting.
- Gregory_Miller
Nice looking early, but it appears you have some engine seals missing on the driver's side, you will want to get those installed if you haven't already.
- Fast Eddie
- Corvair of the Year
I agree with Greg. Very pretty EM, but missing dip stick grommet.
Yeah it's missing a few things, guess I need to spend some more$$ on it lol. Thanks for comments.
- Fast Eddie
You've done a great job making that little '60 into a really nice ride. She doesn't look 55...
Thank you Fast Eddie!!
Great job to all! Ganue60 the little items that are left are really quite inexpensive.
1. Dip stick grommet. Bushing from an upper shock absorber is the perfect size.
2. PCV hole in the top shroud. Plastic hole plug from Lowe's or any hardware store. Put the screws back in the outer holes.
3. Remove fuel pump and rod. Fill hole with correct size freeze plug.
I'm curious about the engine in the 1960 Caveman. Is it a 1965 or later engine? It has a harmonic balancer from a 1964 or later engine, and an alternator from a 1965 or later. The carburetors are automatic choke units from a 1962-1969, but the choke actuating rods are not installed and the vacuum break mechanisms are missing. I think I can see a choke actuating connection next to the left spark plug boot, so completing the automatic choke system should not be difficult. The distributor is 1962-1969 vintage. There is a magnesium blower from 1964 or later, and one of two fan belt guides from 1965 and later (the top shroud belt guide and mounting holes are missing). The top shroud is apparently 1963-1964 with an opening for a PCV system. Is there a road draft tube installed? You might consider opting for a full PCV system, as I believe it does a better job of removing contaminants from the crankcase and keeps the oil and crankcase cleaner. The air cleaner assembly appears to be 1961-1962 vintage, as it does not seem to have the necessary PCV hose connection, as shown in the illustration below.
I love the two-tone interior and exterior paint, and custom wheels. I believe it is one of the best-looking mild custom caveman Corvairs I've seen.
Thanks Brad for all the pointers and info, the fuel pump has the plug in it already as this pic is an older one and I did realize that until I posted it. But I do need the dip stick grommet still. And also thanks for the nice comments on how it looks.
Brad also all that you mentioned is correct the engine is a late model and yes I do have the PVC valve in place it's just hidden under the top shroud and I live in Az so the chokes are not really necessary out here it doesnt get cold here hahaha!!
I'm not sure why you would ever want to place the PCV valve under the top shroud. Whether it is a fixed orifice or a PCV valve, it needs to be cleaned and serviced periodically, since it is subject to getting clogged. Placing it under the top shroud makes it inaccessible and leaves a hole in the top shroud, which is a cooling air leak. In addition, for a PCV system to function properly the PCV valve or fixed orifice must be connected to the vacuum balance tube, and the other tube on the PCV system must be connected to the air filter assembly.
As I said before the pic is and older pic the hole has been covered. As for accessing the valve it is from the back side of the top shroud. And it is connected for the necessary places also I have no issues with how the car runs at all here in hot country Az.
- ncwitte
Hi! I'm trying to be a little more active over here and post more. Looks like there are a couple of beautiful cars already entered for April. I'll toss my hat in the ring because I already know that there's no shame in losing this one.
I'm entering my '65 Corsa turbo convertible. This car was pretty much a complete restoration over an 18 month period and was completed in November 2005. Except for the wheels currently on the car, it's mostly stock, though I did make some color changes.
Here are a bunch of pictures; I'll start with one after, then some befores, and then some afters again:
And now some befores, shortly after I bought this car on eBay:
Ok, enough of that. Here are some more pictures of a shiny car. I will start with some from right after the restoration, showing it with the original wire wheel covers:
And some more recent pictures.
Someday I'd like to put redlines on the car. If I do it will look like this:
Norm Witte
Lansing, Michigan
http://www.wittelaw.com/personal
viewtopic.php?f=52&t=4208
Lansing, Michigan
- ncwitte
Rondo, I love the color combo on your convertible. That is just plain gorgeous.
Norm Witte
Lansing, Michigan
Lansing, Michigan
