VOTE - Corvair of the Month JUNE 2017
Poll ended at Sat Jul 01, 2017 9:32 pm
Cfred
2
8%
socalclassic
3
13%
Freddie
5
21%
jcwildcat85
1
4%
Gregory_Miller
5
21%
ihscomputers
8
33%
Total votes: 24
Cfred
Re: ENTER - Corvair of the Month JUNE 2017
Post by Cfred »
socalclassic
Post by socalclassic »
1962 Greenbrier deluxe 80HP\4 Speed. Bought 1 1/2 years ago. All systems rebuilt or replaced, Fuel, Brakes, suspension, Front end. Dual master cylinder. New tires. This photo was shot ( taken in San Bernardino CA ) just before drivetrain removed. Trans had no reverse ( not a linkage problem). Rebuilt trans and Diff will be install along with a low mileage 110HP (Car) engine. Bought the van 1 1/2 years ago, The last time the van was registered was in 2002. The van engine was started 2 week after bought it.
Freddie
I would like to put my corvair in for the month
Post by Freddie »
Coupe
Sent from my SGH-M919 using Corvair Forum mobile app
jcwildcat85
Re: I would like to put my corvair in for the month
Post by jcwildcat85 »
I would like to put my Corvair in for Corvair of the month. My Corvair is a 1966 Corvair Monza Convertible with 110 engine. This was redone by the previous owner. When he passed away I asked the family about buying it but they wanted to hang on to it for memory sake but I would be the first to get it when they were ready so in the meantime they had another one same year and model but was Tropical Turquoise with aqua interior and a white convertible top that was the son-in-law's aunts car so I had that for 13 years when they said they were ready to let go of this one. I had to get the steering fixed and new tires then I had electronic ignition put in. I found out that the ethanol gas did a number on the carbs and the gas tank and fuel pump so after getting all those replaced it's running very well.
Sent from my SAMSUNG-SM-J320AZ using Corvair Forum mobile app
Gregory_Miller
Post by Gregory_Miller »
Past Corvair of the Month winner, but have done a few things since the last time I entered. Still needs a paint job, but have replaced the carpet, a number of small interior parts in the correct black (the car was originally red inside), the mechanical clock which I nursed along for 3+ years replaced with Quartz movement, internally-regulated alternator added (with dummy regulator still in place for a more stock appearance) All engine tins powder coated black (except the air exhaust tins) Carburetor tops powder coated gold and modded so custom air cleaners fit without notches in the connecting tubes, all 4 carb tops also modded to remove the old bowl vent casting and some light flash removal inside the bases, had exhaust tip powder coated silver as the cheap paint I used on it kept getting burned off. Replaced balance tube rubber hoses with compression fittings, added Roger Parent's epic Heim joint accelerator linkage.
Engine compartment photo showing carb top mods and new accel linkage.
Older side view. I have replaced the tires with correct diameter tires saving RPMs at speed and the speedometer reads very close to perfect now.
ihscomputers
Post by ihscomputers »
1963 V8 Rampside
Custom-built by Ken Arnold in 1998
305 Small Block Chevy V8
Hooker Headers with Camaro Exhaust Tips
TH350 Automatic Transmission
Corvette Independent Rear Suspension
Camaro Alloy Wheels - Fronts Are Custom-Narrowed to 6.75", Rears are 8"
225x50x16 Radials in Front with 245x50x16 in Rear
Rear Adjustable Air Shocks
MSD Custom-Length Plug Wires
Lemonwood Yellow Paint
Shaved Stake Bed Pockets and Gas Filler Door
96" Wheelbase - Rear Quarter Panels were modified to center the rear wheels
3rd Brake Light
Custom-Made Air Scoop under front bumper
Direct feed Gauges - Oil Pressure, Water Temp & Volts
Corvair Bucket Seats
Corvette Center Console Shifter & Lap Seat Belts
Corvair Dash Clock That Works!
Absolute blast to drive and show!!
Dean F. Gemberling
Box Springs, Georgia
Heart of Georgia Webmaster
1965 Monza Coupe w/63 Buick 215 V8 - Former 13-second Drag Car by Ken Arnold
Gregory_Miller
Re: VOTE - Corvair of the Month JUNE 2017
Not that I'm throwing shade.. *wink* but the sweet rampy kinda had the "air" taken out of Corvair. It's a nice water pumper though, don't get me wrong! One more day to vote for a sweet 65 Corsa! :)
