VOTE - Corvair of the Month February 2016
[/center]
Re: ENTER - Corvair of the Month February 2016
Ok, Will enter my Lakewood this month. Attached is a video by the owner of the car who sold it to someone in IN who then listed it for sale using the same video. It is a nice drive around video and shows the car off well. The Wire wheel covers are gone. Correct NOS trim rings and dog dish caps installed now. Also, have added the fold down board behind the seat. Detailed the engine compartment and put a 64 Diff in it so it has a speedo cable hook up now.
It has a 66 110 w/PG.
And I have adjusted the lifters! New muffler too.
Rear NOS arm rests are on and front ones will be on by Helen.
https://www.youtube.com/watch?v=mQWaw46cLr8
And a couple pics at the Choo Choo Event in Chattanooga along with from other events.
That appears to be one nice 1961 wagon! For convenience I went ahead and embedded the YouTube video in your post. If you edit your post you can see how it is done, using the "share_youtube" feature and embedding the URL from the YouTube web page. (Be sure to use the "Share" URL that appears when you click on the word "Share". Do not use the URL at the top of the screen that is displayed by the Web browser. The correct URL source location is displayed in the screen capture below).
The upgrade to a 1966 110 hp engine makes sense, since it provides more horsepower and torque, an alternator-based charging system, a very reliable 110 hp engine, a PCV system instead of a road draft tube, and improved carburetors with automatic choke and the newer distributor design. It should be a reliable setup. Has the distributor been upgraded to utilize a breakerless ignition (Crane or Pertronix), or are you still using ignition points? Such an upgrade can increase reliability even further.
Brad, Put a Pertronix II on it right after I bought it. Funny thing, the coil died at K'noxville on the way to check out the Hiwassee Park location. Got it back, diagnosed it, walked into Clarks and bought one. Then the P-II died the next month. Changed it out and been running fine since. I go no where without a coil, P-II and a belt. Cheap insurance policy!
- Mathew Herda
This is my 1965 Monza. 110HP with a powerglide. I have drove this vair to Kalamazoo and Knoxville to compete for the Ed Cole award.
My 1966 Yenko Stage 1 tribute. Not a real YS so had some fun with Cameo beige and a Black stripe/light fawn interior. 140/4speed. With work to engine. Thanks to my sons Zac and Brandon for 7 years of help. Ken Hand, Virtual vairs and Clarks! Steve Till
This is my 1966 corsa turbo,4spd.I bought this car back 21 yrs ago then sold it to a coworker after driving it for four years,he called me recently and asked if I wanted to buy it back,ummm yeah!!so after lots of work it's looking pretty good!!!
- IMG_628763491484027.jpeg (41.07 KiB) Viewed 2733 times
- FB_IMG_1453788871408.jpg (23.39 KiB) Viewed 2733 times
- FB_IMG_1453788934783.jpg (21.16 KiB) Viewed 2733 times
- FB_IMG_1432497018009.jpg (16.41 KiB) Viewed 2697 times
1960 500 coupe 3spd
1960 700 sedan pg.
1962 Monza coupe 4spd.
1962 spyder convertible
1964 Monza coupe pg.
1964 Monza convertible 4spd.
1966 corsa coupe turbo
1960 700 sedan pg.
